TP-buttons
Hello all
I was wondering if there is a quick trick to turn the channel off for a range of buttons on a touch panel.ie from button 150 to 159.
  • jjamesjjames Posts: 2,908
    You could use a FOR loop.
    DEFINE_CONSTANT
    INTEGER nButtonRange[] = {150,151,152,153,154,155,156,157,158,159}
    FOR(nLoop = 1;nLoop<=LENGHT_ARRAY(nButtonRange);nLoop++)
      IF(nSomeCondition) // some condition
        ON[dvTP,nButtonRange[nLoop]]
    I'm sure you've already thought of this - but . . . that's how I would do it (maybe). Not sure if there is a way to group buttons / channels together. You would think that it *should* be like a DEV array, where you could send a command to all panels such as SEND_COMMAND dv_TP, "'@PPX'". Who knows! I don't think that's the case though.
  • mpullinmpullin Posts: 949
    The Netlinx Keyword help for OFF suggests that the channel parameter can be an array. Try OFF[dvTP,nButtonRange]
    thanks guys, I'm so brain dead from jamming code I can't even think up something as simple as to turn a relay on.
  • MathieuMathieu Posts: 25
    could try that
    DEFINE_MUTUALLY_EXCLUSIVE
    ([PANEL,150]..[PANEL,160])
    On[PANEL,160] // all buttons from 150 to 159 go off ...
    it could be a solution if the 160 button is not used, and if there no other mutually exclusive order
  • Simply turning on an array works.
    You could populate this integer array with specific events that are happening so that it's contents always varied if need be.
    INTEGER_ARRAY_BUTTONS[] = {159,160,161,162,163,164}
    BUTTON_EVENT[dvTP_12INCH,1]
    PUSH:
    ON[dvTP_12_5,INTEGER_ARRAY_BUTTONS]
