Using IR Hex Codes from Pronto
Greetings,
I recently came acoss some discrete IR commands for power on and power off for some devices that AMX does not support. On the Pronto home page they list hex commands for many televisions, etc. Most are 60 or so bytes long. How can these be implemented in the AMX world?
I tried send_string to an IR/serial port with no luck.
  • You can import raw Hex code using IRedit. It gives a prety good example about this in the "help" section of IRedit. I just typed Hex in the search window and it popped out a list of info to select from.
