Expansion Cards
in AMX Hardware
Hi,
I have a NI-4000 with extra comm expansion cards. I have standard extron device hanging off these, but when I try and put a NEC LCD 4010 onto one of these - I don't seem to be getting control ? Out or In. If I move the NEC LCD 4010 to Serial Port 7 built in it works fine ??
The only difference I can see is the 'String Size' which is 196bits on the card but only 64bits on the in built ports ???? This stat comes from check port.
Any ideas...
Ed
Any ideas...
Ed
I've had once i had to press the cards in violently (sort of) to get them "clicked" in
Hi,
Yes the cards are in - if I send a strin I can see the red led light up. The problem is I have put this LCD onto a card which normally controls a extron switcher perfectly...
Ed
You can check the settings of the card in terminal by sending a GET BAUD command and watching the diagnositics.
