Home AMXForums Archive Threads Residential Forum
Weatherhawk control
I have connected a Weatherhawk station Model 916 to an NI-3100 using the AMX module, and I am getting data from it, but the data is not reliable. Has anyone out there have much success with this interface? Any tricks to consider to make it more reliable?
    We've done a few of these and have had good results. When you say unreliable, what things are you not seeing? There are times when the station reports back all zeros in the data, but I just ignore them. Is that what you're talking about?
  • Some variables are not reporting correctly. The HIGH and LOW temps are reporting the same value. HEAT INDEX and WIND CHILL are not correct as well. How often do you query the Satation? I am querying it ever 20 seconds. Did you do any modifications to the AMX UI module and is it possible to share them?
    Ricardo
