Direct TV H21 IR Remote Capture Issues
Has anyone heard of issues coming out fron the new Direct TV H21 receiver? I have yet to caputre its remote but do have some projects coming down the pipe that are using them.
Our techs who program Niles and whatnot are saying the new IR remotes are uncapturable. (I've read something about them using a clock chiped IR emitter that doesn't use of the accepted frequencies or something) They also report that the older H20 IR codes do not work as well.
Direct TV has seemed to taken on a rather negative stance with integraters as of late. I'm not sure what that's all about. However, deliberately designing an IR remote that cannot be captured seems to be biting one of the hands that feed them. (IMHO)
When I do get round to testing it, I'll try the IRIS's advanced (capture anything ) mode and see what happens. It's a pain since you have to resend IR commands to the IRIS 4 or 5 times each code before you get the verified LED to light up.
I had read some web board posts complaining about it but generally, I don't see an issue.
Oh well, all's well that ends well.
e
I've never bothered with the USB because of the 1-way nature of it. However, can you show me the way to the USB protocol. I'm rather curious about it anyway.
(edited to add...)
Oh, and are you connecting a Netlinx master to this via USB? If so, how?
thanks
ejm
The older receivers used the RJ-11 jack, newer ones use a USB port.
Here it is with HR21 and HR21 P added.
DHawthorne, we had some Direct TV boxes about 2 years ago that were using the Serial Ports to communicate to AMX, but DirectTV decided to Disabled the SatBoxes RS232 control. Is this situation still true in 2008 for the Direct TV box H21? We'd really like to use the RS232 control again, if it still works with the H21 boxes.
The new HR-21's have reinstated the RS-232 port for real. (It's a port on the back labeled thus) I was very disapointed in the protocol in general. It's really only 1 notch above the functionality you get from just using IR in that you only get the current channel back. (If you poll for it.)
For all the trouble of doing the protocol, I'm just using IR.
Thanks Eric, know anyone who's created a module already? And who is currently using the H21's serial port at some locations. (It was a nightmare back in the day when DirectTV turns off the Serial ports via a remote update. Very annoying.)
Ok, so then i could purchase nine H21's for a video wall install and pre-order some AMX gear to talk to all the boxes via RS232 (And USB adapters to go with) and be confident that the H21's serials ports will work as of today. This is true? Has Anyone got a module for this already that i could just use?
