Retrofit lighting control solution
I'm looking for a low cost retrofit solution to implement a lighting control for my demo system (I have a NI4000).
Obviously, installing cables in existing walls is the issue.
Anybody ever used Leviton Vizia-RF? Other systems?
Comments and recommendation are welcome.
With UPB, you must have a neutral available at each switch.
The only things that I have found to interfere with UPB communications are electronic fluorescent ballsts and variable speed motor drives. Filter networks can help in these situations.
I would strongy advise that you use the PCS brand dimmers with their newly-released "G2" firmware. It is MUCH more noise immune than previous PCS devices and UPB devices made by other manufacturers. Further I have had some very big problems with non-PCS brand devices being very sensitive to powerline spikes.
I can't speak for Gary's. He did send me a demo of it that I took a quick look at. It seemed quite polished and I have no reason to beleive that it would not live up to its promises. He had a UI with it as well.
Mine is a very elaborate comm module with no UI. Without getting into the whole inner working of UPB, the dimmers can be controlled by a direct-type command or broadcast (UPB link) commands. In the case of broadcast commands, no feedback would be available. Much of the work I put into my system is creating accurate feedback regardless of the mode of control. My module allows you to configure the UPB system at will with the manufacturer-provided UPB Upstart software. One you're done, you reboot the AMX, it polls all the dimmers for config info and bases feedbacks on what it finds.
I have not sold it as a module to other programmers to this point. I have sold it into my own systems and those I write for other dealers. I've sold it for resale for $400 ($399.99 if you watched 60 minutes last night) and MSRP'ed it for $700. I put it out sealed, basing its operation on the serial number of the master.
