How can I get Text Value from a button on TP?
How can I get Text Value from a button on TP? I have a button with a text inserted by the user by a numeric keyboard. How can I read the value?
Alex
    Have you tried this?
    "'?TXT-<vt addr range>,<button states range>'"
          Get the current text information.
          Syntax:
                SEND_COMMAND <DEV>,"'?TXT-<vt addr range>,<button states range>,<optional index>'"
          Variables:
                variable text address range = 1 - 4000.
                button states range = 1 - 256 for multi-state buttons
                  (0 = All states, for General buttons 1 = Off state and 2 = On state).
                optional index = This is used if a string was too long to get back in one
                  command. The reply will start at this index.
                custom event type = 1001:
                      Flag   - Zero
                      Value1 - Button state number
                      Value2 - Actual length of string
                      Value3 - Index
                      Text   - Text from the button
                      Text length - Button text length
          Example:
                SEND COMMAND Panel,"'?TXT-529,1'"
                Gets the button 'OFF state' text information.
                The result sent to the Master would be:
                      ButtonGet Id = 529 Type = 1001
                      Flag   = 0
                      VALUE1 = 1
                      VALUE2 = 14
                      VALUE3 = 1
                      TEXT   = This is a test
                      TEXT LENGTH = 14
