A few questions regarding animated buttons
I have an animated button with 100 states.
The Animate Time Up is 90 and the Animate Time Down is 0.
I have Auto-Repeat set to yes so that the animation loops on its own.
1) Is it possible to use a SEND_COMMAND to tell the button to pause the animation at its current state?
2) On the flip side, is it possible to use a SEND_COMMAND to tell the button to resume the animation from its current state?
I?ve tried using the ^ANI command but I haven?t figured out the correct parameters to make this happen. ^ANI is defined as follows:
3) Regarding the Auto-Repeat parameter that is set at design time: The only way I can make Auto-Repeat work is to also set Feedback for the button to Always On. Is that the way it?s supposed to work?
4) Is there a SEND_COMMAND to control the Auto-Repeat parameter?
Thanks to anyone who can answer any or all of these questions.
Cheers,
Joe
I?ve tried plugging in 0s for start state and end state and left out the optional time parameter out to try and pause the animation. However all that did was stop the animation completely once it reached the last state. I?ve tried several other combinations with no success."'^ANI-<vt addr range>,<start state>,<end state>,<time>'"
Run button animation. Time is in 1/10 seconds and is optional. 0 for
state means current state.
Cheers,
Joe
