NI700 losing communication
                                  in AMX Hardware
                    I have NI700 , MVP8400 and CV5 in system, connected over US Robotics switch.
After some hours working, I cannot access NI700 from NetLinx, and I cannot ping master.
When I reboot it (plug out power), it works fine for a while.
Do any one have solution, or source of the problem?
- May be another device started to use the same IP
- Check memory status... may be it ran out of memory
>url list The following URLs exist in the URL connection list Entry 0-192.168.9.30:1319 IP=192.168.9.30 State=Looking up IP ->Entry 1-192.168.9.35:1319 IP=192.168.9.35 State=Issue Connect >show mem Volatile Free : 23388632 (largest free block in bytes) NonVolatile Free: 522420 (bytes free) Disk Free : 10471424 (bytes of free space) >disk free The disk has 10471424 bytes of free space. >If you Ni 700 does not answer on ping how you have got in telnet? If nevertheless the controller answers on ping, but you cannot come on http, what version master firmware in yours unit? If the old version I advise to update, or to use set duet memory look tech note 766
How to remove it from url list ?
Ni700 have IP 192.168.9.30 witch is in URL list. Other device is PhilipsPronto remote controler.
You don't need nothing in this list unless you connect multiple Netlinx controllers together
