WEB-pages fail
Hi Everyone
I'm having a weird problem with some of the computers in my office and trying to open a web-panel. My computer works fine and opens everyone I select. However when I try to open the same WEB-panel from a different computer they lock up. I can log into the 'box' and see the tabs to select from but when I try to open the web_panel it hangs. I looked and every computer seems to have the same Java version. Has anyone else seen this problem or knows of the cure?
The web panel just crashed upon opening or sometimes wouldn't open at all. It had to do with AMX switching from using virtual machine from microsoft to sun.
I installed the sun java package. That worked fine. for the client i just reverted back to using tpdesign 3.16 older build (i think 193) which worked also.
What version of SUN Java are you running with? This is what we were thinking the issue was rising from. When AMX releases the Duet will it be the SUN or MS(while it lasts) version?
I believe the file you want to install is:
j2re-1_4_2_04-windows-i586-p.exe and you can get it at:
http://java.sun.com/webapps/download/AutoDL?BundleId=9812
Stick with the Sun version. I?m 99.99% sure that DUET is Sun not Microsoft.
Joe
*Crosses his over caffienated twitching fingers and hopes they didn't go with Microsoft*
Just had to chime in
Sorry, couldn't resist.
Joe
*Crosses his over caffienated twitching fingers and hopes they didn't go with Microsoft* -Jeff: I find that more coffee with coke chasers help the twitching fingers. Just make sure it's real coffee and not that de-caff cr**.
Unfortunately, when I wrote that I was down to the bottom of my last 2 liter of coke and there was no coffee available :O (Could have also been because I had skipped breakfast and lunch in favor of coding)
Sorry for what may seem obvious, but opening more than one session of the same panel requires some tweeking to be done at design/download time.
The problem turned out to be some no-longer-valid DNS entries in the TCP/IP Properties for the laptop's ethernet connection. They kept the machine searching for the DNS servers until it timed out, before looking at the controller's IP address directly.
Eliminating the DNS entries entirely allowed the laptop to go directly to the IP address of the controller within the controller's own timeout.
I hope this helps.
For web panel support, make sure to use the 1.4.x version of Java - stay away from 1.5.
- Chip
It is easy to allow multiple web panels on multiple computers all controlling the same things. You make an array of web panels. Combine them with one actual local panel for instance 11001. Link your feedback to the local. WE have 8 running with no problems all updating feedback. Sorry your web panels then are like 33001-33008. Combined with your local panel. We even control feedback from multiple masters on these web pages, between 20 or so controllers. IT works well. I don't believe anyone It has ever been written how to do this. We kind of just figured it out.
