Variable_To_String Limitations
Hello,
i had already use the Variable_To_String function to save data on flash drive.( with the file_write keyword)
Today i tried to save a structure, i already did that but never with interger array on the struct. it seems not working ! Someone tried it already?
my code example :
for testing with the struct :
there is no error during encoding and decoding variable, no error during writing to file ans reading, but i never get back my integer array. Single integer is right read, but not array.
Char and char array are right read.
any ideas?
my code example :
// Writing the struct on file
define_call 'Ecriture_Fichier_Preset_Grille_HDSDI'
local_var
slong File
slong Convert_Success
slong File_Result
char Binary_String[90000]
File = File_Open('/Grilles/Grille_HDSDI.txt',2)
Convert_Success = Variable_To_String(Tab_Preset_Grille_HDSDI, Binary_String, 1)
File_Result = File_Write(File, Binary_String, 90000)
File_Close(File)
// reading struct from file
define_call 'Lecture_Fichier_Preset_Grille_HDSDI'
local_var
slong File
slong File_Result
File = File_Open('/Grilles/Grille_HDSDI.txt',1)
Convert_Success = File_Read(File, Binary_String, 90000)
File_Result = String_To_Variable(Tab_Preset_Grille_HDSDI, Binary_String, 1)
File_Close(File)
structure Struct_Preset_Grille_HDSDI
Char Label[11][50]
integer Preset_HDSDI[64] // <= here is the issue !!!!
integer I_count // <= no issue
any ideas?
I tried to change my way of thinking, so if we could only use char array, i convert all my interger array to char array and save my char array. after that we i read the char array i convert the string in integer... it's not a nice solution but it works..
my decoding and encoding calls
// Conversion de la structure pour bug fonction define_call 'Encoding_VGA_Struct'(Struct_Preset_Grille_VGA Tab_Preset_Grille_VGA[],Struct_Preset_Grille_VGA_Converted Tab_Preset_Grille_VGA_Encoded[], integer Struct_Size) { local_var integer N_Count integer M_Count char String_Temp[3] for(N_Count=1;N_Count<=Struct_Size;N_Count++) { for(M_Count=1;M_Count<=Groupe_Surveillance;M_Count++) { Tab_Preset_Grille_VGA_Encoded[N_Count].Label[M_Count] = Tab_Preset_Grille_VGA[N_Count].Label[M_Count] } for(M_Count=1;M_Count<=8;M_Count++) { String_Temp = itoa(Tab_Preset_Grille_VGA[N_Count].preset_VGA[M_Count]) Tab_Preset_Grille_VGA_Encoded[N_Count].preset_VGA[M_Count] = String_Temp } } } // Conversion de la structure pour bug fonction define_call 'Decoding_VGA_Struct'(Struct_Preset_Grille_VGA Tab_Preset_Grille_VGA[],Struct_Preset_Grille_VGA_Converted Tab_Preset_Grille_VGA_To_Decode[], integer Struct_Size) { local_var integer N_Count integer M_Count char String_Temp[3] for(N_Count=1;N_Count<=Struct_Size;N_Count++) { for(M_Count=1;M_Count<=Groupe_Surveillance;M_Count++) { Tab_Preset_Grille_VGA[N_Count].Label[M_Count] = Tab_Preset_Grille_VGA_To_Decode[N_Count].Label[M_Count] } for(M_Count=1;M_Count<=8;M_Count++) { String_Temp = Tab_Preset_Grille_VGA_To_Decode[N_Count].preset_VGA[M_Count] Tab_Preset_Grille_VGA[N_Count].preset_VGA[M_Count] = atoi(String_Temp) } } }my final writing and reading functions
// sauvegarde dans un fichier txt en binary mode define_call 'Ecriture_Fichier_Preset_Grille_VGA' { local_var slong File slong Convert_Success slong File_Result char Binary_String[90000] //Struct_Preset_Grille_VGA_Converted Tab_Preset_Grille_VGA_Encoded[Taille_Tab_Preset_Grille] call 'Encoding_VGA_Struct'(Tab_Preset_Grille_VGA, Tab_Preset_Grille_VGA_Encoded, Taille_Tab_Preset_Grille) File = File_Open('/Grilles/Grille_VGA.txt',2) Convert_Success = Variable_To_String(Tab_Preset_Grille_VGA_Encoded, Binary_String, 1) File_Result = File_Write(File, Binary_String, 50000) File_Close(File) FILE_COPY ("'/Grilles/Grille_VGA.txt'","'/Grilles/Grille_VGA.bak'") //info to user send_string 0,"'AMX -> File : Save Presets VGA To File'" } // relecture du fichier cr?? avec la fonction "Save_Tab_Unit" d'un tableau Tab_Unit en binary define_call 'Lecture_Fichier_Preset_Grille_VGA' { local_var slong File slong Convert_Success slong File_Result char Binary_String[90000] //Struct_Preset_Grille_VGA_Converted Tab_Preset_Grille_VGA_To_Decode[Taille_Tab_Preset_Grille] File = File_Open('/Grilles/Grille_VGA.txt',1) send_string 0,"'File : ',itoa(File)" Convert_Success = File_Read(File, Binary_String, 50000) send_string 0,"'Convert_Success : ',itoa(Convert_Success)" File_Result = String_To_Variable(Tab_Preset_Grille_VGA_To_Decode, Binary_String, 1) send_string 0,"'File_Result : ',itoa(File_Result)" File_Close(File) call 'Decoding_VGA_Struct'(Tab_Preset_Grille_VGA, Tab_Preset_Grille_VGA_To_Decode, Taille_Tab_Preset_Grille) //info to user send_string 0,"'File -> AMX : Load Presets VGA From File'" }my new temprary struc for the conversion// Presets de grille structure Struct_Preset_Grille_VGA { Char Label[Groupe_Surveillance][50] // 11 noms dans le preset, integer Preset_VGA[8] // indice = Input, valeur = Output } // convertion structure structure Struct_Preset_Grille_VGA_Converted { Char Label[Groupe_Surveillance][50] // 11 noms dans le preset, char Preset_VGA[8][3] }BEFORE the struct is written out to file.
Edit: Oops, typo in my code. Based on your code sample, the code would be as above.
why does it work with char array and not with interger ? i don't really understand your answer...
