NI-700 - Need more IR ports
![Pep_SD](https://us.v-cdn.net/6031006/uploads/customavatars/0/navatar_4100.gif)
in AMX Hardware
I have an NI-700 and I need 1 or 2 extra IR ports.
Could anyone share the different options I have to implement this?
Since it's for my own system at home, the low cost solution is preferred (if there is one).
Thanks !
Thanks !
http://www.amxforums.com/showthread.php?t=2189
Joe, Dave and TurnipTruck: thank you!! You guys rock!!
I've been reading the forums for a few months and I've learned a lot with all of you and several of other regular others like Spire_Jeff, Vining, Eric Medley, Yuri,Matt Pullin, Jay James, Thomas Hayes, Stephen Bolton (I apologize for the ones I'm forgetting here)
Now on my way to complete my AMX practical programmer ... :-)
By the way my house system is an NI-2000 and I now have eight Axcent 3 as port slaves throughout the house. I have run into no problems in using Axcent 3 within Netlinx based systems. As far as I know, the only limitation is the buffer sizes in the serial ports. The bus speed could be an issue if you have really chatty stuff, but probably not in a residential environment.
