MythTV
Has anyone had any dealings with a MythTV setup? I would like to build one for myself, but have never talked to anyone that actually had one or has used one. The website for it is www.mythtv.org. Looks like it would be a fun project to play with and see what kind of control I can get out of it.
#!/usr/bin/perl use Mysql; #Example Usage: ./mysql_connect.pl "SELECT * FROM videometadata WHERE title LIKE 'p%'" #Above will return all info for titles starting with P or p. $sql_query = $ARGV[0]; $db = Mysql->connect(localhost,mythconverg,mythtv,mythtv); $db->selectdb(mythconverg); $query = $db->query($sql_query); $numrows = $query->numrows; while ($numrows>0){ @array = $query->fetchhash; foreach $query (@array){ print $query."\n"; } $numrows=$numrows-1 }currently I run the current trunk of SVN
I control it using the telnet protocol. Have a very basic modul for it for control, that takes advantage of some special things.
Also I think about improving the protocol to have more control functions.
Getting the list of all programs for example.
But I run out of time at the moment :-(
MythTV is a great peace of software !
