About Null or Not Null serial cable
HI
Sorry for this stupid question about serial cable but I'm confused.
Wish cable I have to use between my PC and NIxxxx controler, Null or not Null?
If I build this cable, I have to cross pin 2 &3 or I do a straight cable?
Thanks in advance
    You need a null modem (crossed) cable between a PC and a Netlinx NI-xxxx master:
    PC
    Netlinx Master
    2<
    >3
    3<
    >2
    5<
    >5
  • DenisDenis Posts: 163
    Tank you Joe it's appreciate
  • ImpaqtImpaqt Posts: 155
    A Pretty reliable Rule of Thumb is
    Same connectors on Both Sides = Null
    Opposite connetors = Straight throughThere are exceptions to any "Rule" but this is probobly 90-95% accurate.(Marantz...... Grrrrr.....)
  • annuelloannuello Posts: 294
    Sorry, but I'd have to disagree. I've found that the gender is NO indication of whether you should use a cross over or not. I wish that the whole industry would adhere to such a standard, however they don't. Experience has tought me that you should ALWAYS check the documentation rather than hope.
    Having said that, I've built a little inline adaptor, D9f to D9m. The Tx & Rx lines run through a DPDT switch, so at the flick of a switch I can cross & un-cross a null/not-null cable. I found it very useful for work in the field.
    2 -------0          0          0-----+
             |          +---------------------------- 2
                        +---------------------------- 3
    3 -------0          0      +---0     |
    5 ----------------------------------------------- 5
    Roger.
