Easy Web Control
[Deleted User]
Well, I send files to my NI3000 Master Controller using my TCP/IP connection.
I use a VPT-CP Touch Panel to control my NI3000.
I tried to use the Save As Html TP Design 3 Option to put the created files into the NI3000 FTP server but I failed to log in since it requires a username and a password and I can?t log in using an anonymous user.
The Brazil?s dealer said that I can?t use this option if I have a One Way TP. Is that right ?
Does the exported HTML file comunicates just with a TP? Can?t it comunicate with my NI3000?
Is there an easy way to control my NI3000 via Web as easy as it was to send Netlinx files to it ?
And a hard one?
Sincerely,
Andr
And a hard one?
Sincerely,
Andr
Check out this post: http://www.amxforums.com/showthread.php?s=&threadid=335 for an explanation of web control and see if that gets you going.
Check out your previous post: http://www.amxforums.com/showthread.php?s=&threadid=290 for an answer to your FTP question.
Hope this helps.
Joe
