Infrared codes for Sony DAV-DZ230
Hello,
I'm looking for infrared codes for the Sony DAV-DZ230 Home theatre system. I only need the codes for on /off. I've tried other available (Sony A/V receiver) codes, but i can only get the device to go to standby (system off code). I can't seem to find a code to power it on.
Richard Herman
Richard Herman
First of all you'll need to work out the device code for the unit you're working with by transcribing the bit pattern of one of the commands you already have from the waveform view in IREdit.
I used the following links when writing out the codes for my Sony receiver. I'm using Control A1-II as opposed to IR, but the codes are basically the same.
http://www.undeadscientist.com/slink/ircommands.html
http://www.hifi-remote.com/sony/Sony_rcvr.htm
http://www.remotecentral.com/features/irdisp2.htm
Note that not all Sony equipment responds to discrete power on and off commands. This is especially the case with consumer gear that is manufactured for Sony by other companies (older HD set top boxes spring to mind).
