HOWTO: Double Push!!
A very simple function, but I consider it a good idea since most people used to the concept of Double Click, so why not having a Double Push
It still need more modifications
Any contributions are welcomed, and I will update the main post
DEFINE_FUNCTION INTEGER fnDblPush(INTEGER nBUTCHAN)
//nDBBUTTONS[] an array to indicate first or second push for a range of input channels
//lDBBUTTONSTIMERS1 an array to store at what instant a channel has been pushed
//lDBBUTTONSTIMERS2 another array to store at what instant a channel has been double pushed
IF(DBBUTTONS[BUTCHAN]=1)//If it was pushed before??
DBBUTTONS[BUTCHAN]=2//make this the second push
ELSE//if it was pushed twice before??
DBBUTTONS[BUTCHAN]=1 //make it the first push
SWITCH(DBBUTTONS[BUTCHAN])//Now.... Which push is it??
CASE 1://FIRST push
DBBUTTONSTIMERS1[BUTCHAN]=GET_TIMER //what time is it now?
CASE 2:// SECOND push
DBBUTTONSTIMERS2[BUTCHAN]=GET_TIMER//what time is it now?
//If the time interval between the first and second push OR the second and first push is less than 6 tenths of seconds
IF((DBBUTTONSTIMERS2[BUTCHAN]-DBBUTTONSTIMERS1[BUTCHAN])<6 OR (DBBUTTONSTIMERS1[BUTCHAN]-DBBUTTONSTIMERS2[BUTCHAN])<6)// then it is a DOUBLE push
RETURN 1
ELSE
RETURN 0 //single push
BUTTON_EVENT[dvTP,1]
PUSH:
LOCAL_VAR INTEGER DOUBLED
DOUBLED = DB(BUTTON.INPUT.CHANNEL-40)
SWITCH(DOUBLED)
CASE 1:
//DOUBLE PUSH ACTION
CASE 0:
//SINGLE PUSH ACTION
button_event[dvUI, iButton] { push: { if (isSecondPush) { cancel_wait 'Double Push Wait' send_command 0, "'Just received a double push.'" isSecondPush = 0 } else { isSecondPush = 1 wait 5 'Double Push Wait' { isSecondPush = 0 send_command 0, "'Just received a single push.'" } } } }
