lutron loading
not really an AMX question, but maybe someone can help
I am working with lutron P5 system and homeworks illumination 1.1804.
When I load the system using IP connection, it fails...
When loading with serial cable, its ok.
but this is very slow and I need to go to the basement every time that I need to load the system..
and since now we are adding a lot of virtual keypads its lots of changing all the time...
Any idea?
Ady.
Any idea?
Ady.
the problem is different
I connect and I upload and every thing is ok
80-85% is uploaded and then I get error on one of the DB files, and thats it.
I have to make a full upload via serial...
It would appear, however, that your network has issues. Perhaps your computer has a tenuous connection, or the HWI processor. You might simply be stuck with the serial port.
We had some similar problems with a P5 processor. We were receiving db errors and partial uploads as well as other network connection issues. In our case we had loaded the .hdf file with no problems using HW Illumination 1.23, then modified the file on site and re-loaded using a laptop with HW Illumination 1.22. When we used the 1.22 version it caused the problems I mentioned above.
I think what was happening was that when we loaded using 1.23 it upgraded the OS on the Homeworks Processor, but when we loaded using 1.22 it tried to downgrade the OS. We reloaded the file with 1.23 after the 1.22 upload errors, and it told us we needed to upgrade the OS on the processors. Whenever we tried to use 1.22 software after the 1.23 it caused errors.
If someone else is uploading files to the Homeworks, you may want to confirm that you're using the same version of Illumination as they are, otherwise your 1.18 version may be causing the issues. Again, not sure if this is the problem in your case but maybe this will help out.
--John
This is not the problem
I am loding via serial cable with no errors, everything is working ok.
I think the problem is that only one controller (we have 2 in this huge house) is connected to the IP network, and the loading in IP mode is working direct and not via the first controller like in the serial mode.
We have to arrange network for the second controller too and to see if thats help.
However I do recall a similar problem where the download would stop in the middle with the DB error. If I remember correctly I was connected to a Netlinx processor at the same time and trying to multi task between Lutron and Netlinx. As soon as I disconnected the Netlinx session the Lutron download worked.
