Kramer Vp61xl
Has any one controlled the VP61xl vga switch and if so, what is the strings you send to the device.
  • AMXJeffAMXJeff Posts: 450
    http://www.kramerelectronics.com/software/rs232protocols/VP-61xl.pdf
    http://www.kramerelectronics.com/hexa/VP-61xl.pdf
    // BIT 7: 0 - ALWAYS ZERO
    // BIT 6: 0 - ADDRESS BIT, ZERO IN THIS CASE BECAUSE I ASSUME "MASTER"
    // BIT 5: 0 - ADDRESS BIT, ZERO IN THIS CASE BECAUSE I ASSUME "MASTER"
    // BIT 4: 0 - ADDRESS BIT, ZERO IN THIS CASE BECAUSE I ASSUME "MASTER"
    // BIT 3: X - INPUT NUMBER - LOWER NIBBLE
    // BIT 2: X - INPUT NUMBER - LOWER NIBBLE
    // BIT 1: X - INPUT NUMBER - LOWER NIBBLE
    // BIT 0: X - INPUT NUMBER - LOWER NIBBLE
    // SO...
    SEND_STRING dvKramer,"$01" // INPUT 1
    SEND_STRING dvKramer,"$02" // INPUT 2
    SEND_STRING dvKramer,"$03" // INPUT 3
    SEND_STRING dvKramer,"$04" // INPUT 4
    SEND_STRING dvKramer,"$05" // INPUT 5
    SEND_STRING dvKramer,"$06" // INPUT 6
  • Thanks
    Thanks got it to work
