Duet Module conflict
Im having a problem with 2 duet modules conflicting. I am a new programmer and have a system with 6 serial devices. 2 of them are conflicting with each other. it is a Russound ST2 XM tuner and a toshiba HD-XA2. (yes I know HDDVD is going away) Anyways I have tried every thing i can think of. the only thing that effects them is what order i call them in define_start. If I place the russound before the Toshiba then the russound works. If I place the toshiba first, then the toshiba works.
DEFINE_MODULE 'Russound_ST2XM_Comm_dr1_0_0' COMM1(vdvXM1, dvXM)
DEFINE_MODULE 'Russound_ST2_UI' TP1(vdvDEV_ARRAYXM, dvTP3, nCHANXM, nLVLXM, nTXTXM)
DEFINE_MODULE 'Toshiba_HDXA2_Comm_dr1_0_0' HDDVDMod(VDVhddvd, dvhddvd)
DEFINE_MODULE 'Anthem_AVM30_Comm_dr1_0_0' D2Mod(vdvD2, dvD2)
DEFINE_MODULE 'Fujitsu_Plasma_Comm' mdlFujitsu_APP(vdvtv, dvtv)
All device names are unique as well as all modules. There is also an autopatch and request server modules. The only thing I can think of is they are using the same global variable names in them.
At this point I think Im going to be writing my own code for the toshiba since its the easyest and im not using feed back from it.
Has every Comm module a correct Duet Device adress? 41001:1:0, 41002:1:0, etc?
We should have the DEFINE_DEVICE section and maybe also the DEFINE_VARIABLE, to see more details.
Kind regards,
For the person who asked here is the define device code.
DEFINE_DEVICE
DVTP = 10001:1:0 // AMX MVP-8400
arqTP1 = 10001:2:0 // ARQ Touch panel device 1
dvTP3 = 10001:3:0 // XM Touch Panel
DVTPKTCHN = 10002:1:0
//IR Devices
DVCbl = 5001:9:0 // Scientific atlantic cable box
DVSatRec = 5001:10:0 // sony sat-HD300 DSS receiver
DVBlry = 5001:11:0 // Blueray player
DVAppl = 5001:12:0 // apple tv
DVAnth = 5001:13:0 // anthem ir
// Seriel Devices
DVD2 = 5001:1:0 // anthem D2
DVHDDVD = 5001:2:0 // Toshiba HDDVD Player HD-XA2
DVTV = 5001:3:0 // Fujitsu TV
DVAP = 5001:4:0 // optima Autopatch switch
dvXM = 5001:5:0 // Russound ST2 Serial Port
//network Devices
dvARQ1 = 0:2:0; // Set IP in ARQ Main v5_0_1.axi
//Virtual devices
vdvXM1 = 41001:1:0 // Virtual Device for TUNER AM/FM
vdvXM2 = 41002:1:0 // Virtual Device for XM
VDVhddvd = 41003:1:0 // HDDVD Virtual DEV
VDVtv = 41004:1:0 // Fujitsu Virtual dev
vdvAP1 = 41005:1:0 // 41001 == Duet virtual device (APDuet Module in this case),
vdvAP2 = 41005:2:0 // 41001 == Duet virtual device (APDuet Module in this case),
vdvAP3 = 41005:3:0 // 41001 == Duet virtual device (APDuet Module in this case),
vdvAP4 = 41005:4:0 // 41001 == Duet virtual device (APDuet Module in this case),
vdvAP5 = 41005:5:0 // 41001 == Duet virtual device (APDuet Module in this case),
vdvAP6 = 41005:6:0 // 41001 == Duet virtual device (APDuet Module in this case),
vdvAP7 = 41005:7:0 // 41001 == Duet virtual device (APDuet Module in this case),
vdvAP8 = 41005:8:0 // 41001 == Duet virtual device (APDuet Module in this case),
VDVD2 = 41007:1:0 // Anthem D2 Virtual dev
VDVD22 = 41007:2:0 // Anthem D2 Virtual dev zone 2
VDVD23 = 41007:3:0 // Anthem D2 Virtual dev zone 3
vdvARQ1_1 = 34000:1:0; //Virtual device for ARQ 1, Zone 1
as of a few minutes ago I just discovered that the autopatch module is killing the toshiba also. I just added it to the system. no idea if it effects the russound yet.
It pretty much has to be the automatic virtual device assignments in Duet.
I have some time tomorrow to call amx again and am hoping this gets figured out or I have a real problem.
Its the current one that is still up. when I changed to the last .353 I think it is, everything started working. I even went to the point of doawloading .371 again and reloading it just to make sure something did not currupt. As soon as I put .371 on again only the first module called would work a rs-232 device. IP modules were un-effected.
I lost probably 40 hours into this problem with many hours on the phone with tech suport. They could find no problem with the code and as a last ditch try had me down grade the firmware. I made sure they know about the problem but the firmware is still up 4 days later.
v. 3.30.371 was a disaster for me -- blew up Lexicon DV7600 and autopatch duet modules
Don't know why AMX still have it as the latest and greatest on the web site still. However, get them to send you more recent -- it fixed all my problems ! v3.40.339 NI3100
