NI-4100
Hi everyone!!!
I've got the problem with my NI-4100. After my ethernet failed I can't login to NI through http. Also I try to refresh Device tree in NetLinx Studio but programm shows me notification "Authentication Failed For User Name <Blank User Name>".
I can't understand what should I do in this situation.
Please help me!!!!
    Roddy wrote: »
    Hi everyone!!!
    Please help me!!!!
    Have you tried to connect to it via Telnet? Using a PC, hook up a serial cable to the Master's back port. set up a hyperterminal session to it. The baud is usually 38400 out of the box. You can set up security from there.
  • tttttt Posts: 21
    Is this problem solved please?
    The posts you replied to are 14 years old. If you have a similar issue, describe it in detail.
