lol, just realized that. No reason not to use a for loop there. Also, having to call MAX_LENGTH_ARRAY() every iteration is probably not important unless haystack has billions and billions of hay in it, not likely the case in anyone's home control system. But still I'd rather not.
Isn't that rather unorthodox though, using a function that was designed to find a char in a char array, to find an integer in an integer array? :-|
Sure enough, FIND_STRING(arrADA_VOLUME,"30",1) does not compile.
ERROR: C:\Programming\AMX\???.axs(975): C10585: Dimension mismatch: [0] vs. [1]
ERROR: C:\Programming\AMX\???.axs(975): C10555: Type mismatch in call for parameter [A]
(where arrADA_VOLUME is an integer array of size 13)
Is the integer array sorted? If so then a binary search is easy and fast: O(logn).
If you know the maximum amount of possible integers and they are unique then you could put the integer in the array at the index of the integer. This would then require only one access and would run in O(1) time. It would use more memory but often that is a suitable trade off. For instance if you had an integer array of channel numbers in use, since they are guaranteed to be unique, you could define an array of 4000, and then store the number 1 at index 1, 2 at index 2 etc. If there was no integer at that location then its value would be 0 so you know that integer isn't in the array. Won't work for negative numbers though unless you come up with a clever scheme. Every time you insert a number into the array it goes into its correct element and you only need to do this to find out if the integer is in the array:
if (array[someInteger] == someInteger)
// someInteger is in the array
else
// someInteger is not in the array
Not sure what the application is but if you tailor the way you assign integers to array elements you can find them quite a bit quicker. A hash would be perfect for what you need but you would have to write your own as there is no built in hashing function.
So you do not like FOR loops???? Old School????
So,
I know, I know... I better go find something useful to do...
Thank you guys for the replies. I thought that maybe Netlinx would have a specific function to do that
I can look now for mu needle inside my haystack :P
