Home AMX Technical Discussion
R4 listbox now working with button event
Great it is working
Yes you can push a listboxbutton and get an event from it. Be sure that one column is set up as channel code. No documentation in TPdesign4 on this.
Is their a trick to hide the first ID column ? In the AMX R4 example it is done, but how? No hidden LDA command in tpdesign , but a report will show text in column 1 .
Nick from the Netherlands
