Pretty sure you need to null it as it is 2 Rxd 3 Txd 5 Gnd which is the same as the netlinx. Basically 2 and 3 need to be switched around on one end for proper communication.
The protocol is
[U,D,S][1-5],$0D btw.
So: SEND_STRING dvSomfy,"'U5',$0D"; For example, to make all shutters open.
Also note that you need a 1.5 second delay between each command.
Try something like
Button_event [ALL_TP_ARRAY,nBtnSomfy]
PUSH:
IF (!nsomfylockout)
SWITCH (GET_LAST(nBtnSomfy))
// switch between your operations here, or do something else
nsomfylockout = 1;
wait 15 'somfy lockout' {
nsomfylockout = 0;
I have wired my laptop's serial port directly to the Somfy controller (The black box, 5 channel version, not the white one), and I am trying to send strings directly to it, but I never see the RF LED light up on the box to indicate that it is sending a command to the shades. I am now using my laptop's serial port because I wasn't seeing anything happening when it was connected to the NI. If I use a null modem premade DB9 cable, I get no feedback from the unit. If I use a straight thru premade DB9 cable, I at least get a response when I send a command: hex 00. However, still no RF commands being sent. I can wire the relays on the box and see it send the RF command when I short the relays together, so I know that it SHOULD be working. However, since this is my first somfy 232 interface, I feel as though I'm missing something. Help?
One thing about Somfy is their tech support is pretty responsive. We had an issue with the motors getting all screwed up (they have a limited amount of memory and the electrician over-programmed them), and it took a few tries but they stuck with trying to resolve it. I think the really knowledgeable guy was Abraham or Ezekiel, something biblical .
The last unit I worked with wanted a different baud rate to the manual - either 2400 or 9600 of the top of my head. It would also only work on a short cable.
The protocol is
Try something like
If you don't want to write a command queue.
-John
