Directv's new HR21 Pro Rcvrs RS-232 Control
Has anyone worked with the new Directv HR21 Pro receivers and used the DB-9 RS-232 control port? I have one on an upcoming project and am curious if anyone has had any luck with control from an AMX processor. I have heard that Directv has recalled all units and that prior to the recall, there were serious issues with lockups and lack of control.
Just curious if I should expect the same issues or if anyone has these working properly.
Sheldon Samuels
IPS Resources LLC
Sheldon Samuels
IPS Resources LLC
We had tons of freeze up issues on the 21pro RS232 port, we where forced to switch to USB adapter 232. After about 3 commands you get a freeze up and it takes 8 -10 minutes to reboot. Also the receivers tend to go to sleep (directv logo moving around.) There is still audio but the video goes to screen saver randomly. It drives us crazy.. The only way we found around it is to send an exit command every 5 minutes and it solves the issue for now. Theses boxes update and reset almost every day, this is a huge problem in a 24hour casino environment. These boxes are not ready for use in the pro market or any really. We have a test box in our shop and it will go to sleep in the middle of a movie after only 15 minutes. The sleep issue is really random. Right now if they could fix the sleep issue they would work out if you don't need full feedback.
We have it with 5 receivers. We got replacements and they still do it. Now when you wake them up you get an instructional page.
- Chip
No idea about the screen saver.
- Chip
I hope that DirecTV gets serious about working with integrators some day. It'd be nice.
