Garage door control
Hello everyone,
I searched the forums, search the InConcert db but did not find anything - could you share how you would implement on the hardware side, the control of a garage door ?
I'd like to try it at my house which has a 'Genie ProMax' garage door opener (house built in 2000 in California).
I guess I would use the relays on AMX side - now, what do I need to make the link to the 'Genie'?
Or do I have to change it and get anything special?
Thanks!
Thanks!
I just did a quick test with a NI3100: I manually turned ON channel 1 of port 8 (which is the first relay) with nothing connected to the output of the NI's relay (using Control a device through Netlinx Studio).
Is it normal that I don't get any voltage when I measure it between A and B for channel 1??
I tried to setup my voltmeter to AC or DC, nothing, just gets 0 volt ... Am I missing something?
I would try manual touching the two wires at the garage door opener together to see if it moves. If it does, I don't know any reason a simple really wouldn't work exactly the same.
This basically acts as a switch. Open or closed which will either impede current flow through a circuit or allow it.
If you find the specs on your GDO I'm sure you'll find the control voltage that runs to the GDO button is 24Volt AC or just put a tester across the button and see what it is. I can't imagine the current being 1 A or more so if you wanted it's quite possible you could hook up two wires to A & B of a relay port and connect it to the wires on the back of the GDO button or unit. A parrellel connection.
Should the voltage or current be higher than that specified for the relay port or somehow the OHD guys while servicing the unit does something stupid you may cooked your port so when doing this sort of connection I will normally add a relay for isolation purposes. See attached picture.
The picture shows the OFF state of the relay port and the normally open state of the isolation relay!!
I can't say Thank You enough!! You just made me understand the whole thing...
One more great lesson!
Thank you for the explanations, thank you for the attachment, thank you for the time you took for all this.
I wish I knew more to be able to help others in return...
PEP
