Home AMX Technical Discussion
Controler LOG File
Hallo to everybody,
I am trinig to create LOG File for the Contoler to make diagnostic. I try to write down all the mesages that can get from the telnet .
The problem is that I do not know how to get the messages from the telent, any ideas?
What I try is :
DEFINE_DEVICE
dvMaster = 0:0:0
DEFINE_EVENT
data_event[dvMaster]
string:
send_string 0, data.text
  • It is not possible to get the system's log directly into the NetLinx program. You may program a client IP application into your code, which opens a telnet to the master's IP and then emulates a SHOW LOG ALL (or whatever terminal function you want to have). It may also possible to do that by RS232 from a control port to the programming port.
    You might want to look at this : http://www.amxforums.com/showthread.php?t=1187 . Just make sure you download the latest version there.
  • Thanks Dave Hawthorne
    This is exactly what I need. Great Module
    I have to chack some system that make problems evrey two tree weeks.
