Add page flip forget
Sending ^APF command to a panel is possible to add programmatically a page flip to a button.
I need to set a "page flip forget" to a button, but I cannot find this in the actions that can be sent.
How can I do it?
Thank you
How can I do it?
Thank you
There are rooms with only 4 audio sources, others with 6; in each R4 page we put 4 buttons, so if you want to choose the 5th one you have to scrool using the big blue button.
I'm too lazy to create different pages for every room, so I'd like to do something like that:
if room.sourceCount == 4 clear page flip from big blue button else add page flip forget to big blue buttonWith ^APF I can add only a standard page flip, not a forget, but I need it to make work correctly the back button.
For this specific project I can use a workaround because an R4 will always stay in the same kind of zone, so the "clear page flip" command is enough, but if something changes in specs (and you all know that this will eventually happen!) this quick and dirty solution will not work anymore.
Thank you!
You can add the following actions:
Stan[dardPage] - Flip to standard page
Prev[iousPage] - Flip to previous page
Show[Popup] - Show Popup page
Hide[Popup] - Hide Popup page
Togg[lePopup] - Toggle popup state
ClearG[roup] - Clear popup page group from all pages
ClearP[age] - Clear all popup pages from a page with the specified page name
ClearA[ll] - Clear all popup pages from all pages
As you can see, there's no the "page flip forget"
I'd probably go with what Matt said - flip to a page that doesn't exist. Though - I've been told by tech support that it could potentially mess up a panel (locking up, etc.) but I've never seen it happen.
You have an R4 with the following pages: Main, page1, page1-a, page1-b.
On the main page, there is a button that goes to page1. On page1, a button to go to page1-a. On page1-a, a button to go to page1-b. On page1-b, a button to go to page1. One each of the page1* pages, there is also a back button that uses the Previous Page function.
If you use standard page flips to navigate through the R4, the page visit buffer would look like this: Main>page1>page1-a>page1-b>page1>page1-a>page1-b> .... for as many times as you hit the buttons on the page1* pages. If instead, you use a page flip forget on each of the page1* pages, it does not store the page flips so the page visit buffer would like like: Main>page1. No matter how many times you push the buttons on the page1* pages, it would just keep forgetting them (I think).
Now, if you use the Previous Page button, with page flip forget, you will always go back to Main no matter how many times you flipped through the page1* pages. If you just use the standard page flips, you will have to push the previous page button once for every time you hit one of the page1* buttons and essentially step back through the cycle.
Obviously, if it was as this example is, you could just use a page flip to the Main page instead of Previous Page. The place I found a use for this is when you jump to lighting control that has multiple pages from a device page. If you want to provide a back button, you either have to track everything in programming and handle it there, or you could use page flip forgets when scrolling through the list of light buttons and provide a back button. (This could also be applied to surround field settings
