RCA DirecTV via Serial Control
Greetings,
Has anyone had any luck controlling RCA DirecTV receivers serially? I have come across a fwe web sites with protocol, but they seem to offer conflicting information.
I am looking for any protocol information that anyone may have.
Thanks!!
  • RCA DirecTV via Serial Control
    Yes, I have done this several times. It works great.
    This site has the best info and links
    http://www.dtvcontrol.com/index.aspx?content=cmds
  • I have written a module for a RCA DSS receiver. It is not in the AMX standard format, but it does work. I've included the source and documentation files so you can either use it as-is or can cut and paste whatever you need from it. The documentation assumes that you are using the NXI master with the phoenix connectors. I do have this code running on 14 different systems so it has been tested and works.
    Danny
