Aprilaire works, but be aware that the thermostat itself will only display the humidity (If I recall correctly). I think you still have access to both temp and humidity through the comms tho.
That depends how you set it up. If the stat is set as a humidistat, it takes over the thermostat completely. But, if you leave the humidity as a remote, the thermostat will still show the temperature, and report the humidity on the remote readout.
