Question of timelines
Ok, I've tried it a few times and have discovered that I cannot get timelines to work if I use an array variable in their declaration. I was hoping for an explanation of why.
An example:
The following will not work:
BUT! This works just Dandy!:
Ok... Why?
Ignoring all the possible silly typos and stylistic jibber-jabber(I really need a Mr. T emoticon here!!), I don't see why this shouldn't work.
Isn't the value of TL[1] in the first exercise = 11? As a LONG Constant, the same TL1 (or 10+TWhich_Proj) in the second example?
The first example ALWAYS bogs the rest of the code following to a stop..... No more feedback and mostly poor performance. The controller though gives no indication of any problem in diagnostics or telnet messages.
I was just curious for enlightenment purposes.
Thanks in advance for the information.
An example:
Define_Variable (*Or Sometimes Define_Constant, neither works*)
long Proj_Warm_TL[3] = {11,12,13}
long Proj_Warm_Times= {60000}
Define_Variable (*Always*)
integer nProj_Sel
integer Proj_On_Butt[] = {101,103,105} //Just for the sake of argument
integer nProj_Pwr[3]
integer nProj_Warm[3]
//Fictitious Define_Subroutine Here designation
Define_Call 'Projector On' (integer TWhich_Proj) //VERY Simplified for this exercise
If (! nProj_Pwr[TWhich_Proj] )
on[nProj_Warm[TWhich_Proj]]
timeline_create (Proj_Warm_TL[TWhich_Proj], Proj_Warm_Times, 1, timeline_relative, timeline_once)
Define_Event
Button_Event [tp,Proj_On_Butt] (*I KNOW I didn't define a TP here.... ASSUME it's a Touch panel that has been defined *)
Push:
nProj_Sel = Get_last (Proj_on_Butt)
Call 'Projector On' (nProj_Sel)
timeline_event [Proj_Warm_TL[1] (*Or even as 11*) ]
Off [nProj_Warm[1]]
On [nProj_Pwr[1]]
timeline_event [Proj_Warm_TL[2] (*Or even as 12*) ]
Off [nProj_Warm[2]]
On [nProj_Pwr[2]]
timeline_event [Proj_Warm_TL[3] (*Or even as 13*) ]
Off [nProj_Warm[3]]
On [nProj_Pwr[3]]
Define_Variable (*Or Sometimes Define_Constant you get it*)
long Proj_Warm_TL1 = 11
long Proj_Warm_TL2 = 12
long Proj_Warm_TL3 = 13
integer nProj_Sel
timeline_create ((10+TWhich_Proj), Proj_Warm_Times, 1, timeline_relative, timeline_once)
Define_Event
Push:
timeline_event [Proj_Warm_TL1 ]
Off [nProj_Warm[1]]
On [nProj_Pwr[1]]
timeline_event [Proj_Warm_TL2 ]
Off [nProj_Warm[2]]
On [nProj_Pwr[2]]
timeline_event [Proj_Warm_TL3 ]
Off [nProj_Warm[3]]
On [nProj_Pwr[3]]
Ok... Why?
howsabout this...
TIMELINE_EVENT[0] { CALL 'TIME_EVERYTHING' }Is that part of the SET_OUTDOOR_TEMPERATURE routine?
Now I know there is a definitive answer. I should check the tech notes more often, but oh well.....
And I was really looking for more of a timeline like this:
Define_Constant long Revert_TL = 1 slong Revet_Times= {0,-3600000} Timeline_Create (Revert_TL,Revert_Times,2,Timeline_Relative, Timeline_Once) //Of course this has to be a relative timeline . . . //Testing to get the clock to roll back Timeline_event[Revert_TL] { Switch (timeline.sequence) { Case 1:System_Call 'Set Universal Clock' Case 2:System_Call 'Relieve Stress' }Ahhhhhh... wouldn't that be nice
But again, thank you all for replying, my curiosity is assuaged!
