Old Radias
Greetings,
I have had bad results using older Radia 4 and 6-channel boards on Netlinx masters connected via Axlink.
Most issues are communication related, requiring rebooting the dimmers. They worked fine on the Axcess-based systems they were removed from.
Any idaes?
  • YuriyYuriy Posts: 20
    You need to replace a E-PROM chip.
    Replacement of a chip has helped with my case.
    ORDER FREE FIRMWARE UPGRADE
    Radia Master Firmware v3.22
    Release Date September 28, 2005
    This firmware is programmed into an E-PROM chip and not available as a download. Please order the free replacement chip using part number: PC606-A.
    NEW FEATURES
    Improve ProLink interface error detection and message handling.
    Add new phase/zero-crossing detection and correction features at startup and reset.
    This firmware reduces AxLink controller lock-ups and Radia devices from dropping off line.
    I was told that the 3.x firmware could not be put into my boards that are running a 2.x.
    What firmware did you replace out of your dimmers?
