Comcast smtp ?
Today I created a couple secondary email accounts for a customer with Comcast Cable internet service. Now I've done this several times with several providers and I don't recall ever having so much trouble. The secondary accounts all worked from my PC logging in and sending/receiving emails but using the same username and password in i!-EquipmentMonitorOut I would get this:
Line 75 "Smtp Receive-535 5.7.0 ...authentication rejected,"
59 (21:59:29):: Smtp ONLINE, Line-<840>
Line     60 (21:59:29):: Smtp Receive-220 OMTA07.emeryville.ca.mail.comcast.net comcast ESMTP server ready, Line-<896>
Line     61 (21:59:29):: SMTP Sending-EHLO NetLinx, Line-<617>
Line     62 (21:59:29):: Smtp Receive-250-OMTA07.emeryville.ca.mail.comcast.net hello [24.2.208.239], pleased to meet you, Line-<896>
Line     63 (21:59:29):: Smtp Receive-250-HELP, Line-<896>
Line     64 (21:59:29):: Smtp Receive-250-AUTH LOGIN PLAIN CRAM-MD5, Line-<896>
Line     65 (21:59:29):: Smtp Receive-250-SIZE 15728640, Line-<896>
Line     66 (21:59:29):: Smtp Receive-250-ENHANCEDSTATUSCODES, Line-<896>
Line     67 (21:59:29):: Smtp Receive-250-8BITMIME, Line-<896>
Line     68 (21:59:29):: Smtp Receive-250-STARTTLS, Line-<896>
Line     69 (21:59:29):: Smtp Receive-250 OK, Line-<896>
Line     70 (21:59:29):: SMTP Sending-AUTH LOGIN, Line-<617>
Line     71 (21:59:29):: Smtp Receive-334 VXNlcm5hbWU6, Line-<896>
Line     72 (21:59:29):: SMTP Sending-"base64 encrypted username", Line-<617>
Line     73 (21:59:29):: Smtp Receive-334 UGFzc3dvcmQ6, Line-<896>
Line     74 (21:59:29):: SMTP Sending-"base64 encrypted password", Line-<617>
Line     75 (21:59:31):: Smtp Receive-535 5.7.0 ...authentication rejected, Line-<896>
Line     76 (21:59:31):: Exiting TCP Read thread - closing this socket for local port 23
Line     77 (21:59:31):: CIpEvent::OffLine 0:23:1
Line     78 (21:59:31):: Smtp OFFLINE, Line-<847>
After several different attempts with out success I looked at line 64 "AUTH LOGIN PLAIN CRAM-MD5" and figured maybe they switched to MD5 encryption. I then spent the next hour re-writing the code to provide MD5 encryption instead of the base 64 and tried it again with out any success. The MD5 ecryption worked fine but I still got "Smtp Receive-535 5.7.0 ...authentication rejected" as shown on line 75 above. I then started googling SMTP and other related crap and I noticed "Receive-334 VXNlcm5hbWU6 & Receive-334 UGFzc3dvcmQ6" in several examples and figured, well that's a coincidence and decided to run those strings through a base 64 decoder and found out they were base 64 encrytions of "username:" & "password:" So now I'm back to base 64 encryption and removed the MD5 stuff. I couldn't really find any meaning behind the "AUTH LOGIN PLAIN CRAM-MD5" while googling but figured if they send me base 64 encryptions they must expect base 64 in return just as the module was written.
The only thing I hadn't tried was the primary username & password so after all this I decided to give it a shot and it worked with out a problem. Go figure!
313 (22:06:31):: Smtp Send
Line    314 (22:06:31):: Smtp Connecting-smtp.comcast.net:25 on 23
Line    315 (22:06:31):: Memory Available = 20225848 <91048>
Line    316 (22:06:32):: Connected Successfully
Line    317 (22:06:32):: CIpEvent::OnLine 0:23:1
Line    318 (22:06:32):: Smtp ONLINE, Line-<840>
Line    319 (22:06:32):: Smtp Receive-220 OMTA05.emeryville.ca.mail.comcast.net comcast ESMTP server ready, Line-<896>
Line    320 (22:06:32):: SMTP Sending-EHLO NetLinx, Line-<617>
Line    321 (22:06:32):: Smtp Receive-250-OMTA05.emeryville.ca.mail.comcast.net hello [24.2.208.239], pleased to meet you, Line-<896>
Line    322 (22:06:32):: Smtp Receive-250-HELP, Line-<896>
Line    323 (22:06:32):: Smtp Receive-250-AUTH LOGIN PLAIN CRAM-MD5, Line-<896>
Line    324 (22:06:32):: Smtp Receive-250-SIZE 15728640, Line-<896>
Line    325 (22:06:32):: Smtp Receive-250-ENHANCEDSTATUSCODES, Line-<896>
Line    326 (22:06:32):: Smtp Receive-250-8BITMIME, Line-<896>
Line    327 (22:06:32):: Smtp Receive-250-STARTTLS, Line-<896>
Line    328 (22:06:32):: Smtp Receive-250 OK, Line-<896>
Line    329 (22:06:32):: SMTP Sending-AUTH LOGIN, Line-<617>
Line    330 (22:06:32):: Smtp Receive-334 VXNlcm5hbWU6, Line-<896>
Line    331 (22:06:32):: SMTP Sending-"base64 encrypted username", Line-<617>
Line    332 (22:06:32):: Smtp Receive-334 UGFzc3dvcmQ6, Line-<896>
Line    333 (22:06:32):: SMTP Sending-"base64 encrypted password", Line-<617>
Line    334 (22:06:32):: Smtp Receive-235 2.7.0 ... authentication succeeded, Line-<896>
Line    335 (22:06:32):: SMTP Sending-MAIL FROM: <customer.email.address@comcast.net>, Line-<617>
Line    336 (22:06:33):: Smtp Receive-250 2.1.0 <customer.email.address@comcast.net> sender ok, Line-<896>
Line    337 (22:06:33):: SMTP Sending-RCPT TO: <my.email.address@msn.com>, Line-<617>
Line    338 (22:06:33):: Smtp Receive-250 2.1.5 <my.email.address@msn.com> recipient ok, Line-<896>
Line    339 (22:06:33):: SMTP Sending-DATA, Line-<617>
Line    340 (22:06:33):: Smtp Receive-354 enter mail, end with "." on a line by itself, Line-<896>
Line    341 (22:06:33):: SMTP Sending Message, Line-<486>
Line    342 (22:06:33):: SMTP Sending File-RSSWeather_Return.txt, Line-<547>
Line    343 (22:06:33):: SMTP Sending-$0D$0A., Line-<617>
Line    344 (22:06:33):: Smtp Receive-250 2.0.0 m26Y1Z00B5ASnQ88R26ZeP mail accepted for delivery, Line-<896>
Line    345 (22:06:33):: SMTP Sending-QUIT, Line-<617>
Line    346 (22:06:33):: Exiting TCP Read thread - closing this socket for local port 23
Line    347 (22:06:33):: Smtp Receive-221 2.0.0 OMTA05.emeryville.ca.mail.comcast.net comcast closing connection, Line-<896>
Line    348 (22:06:33):: CIpEvent::OffLine 0:23:1
Line    349 (22:06:33):: Smtp OFFLINE, Line-<847>
In the above snippets I removed the actually base 64 encrypted strings so viewers can't run them through decoders and get the valid username and password but why the heck does just the promary email user/pass work and not the 3 or 4 secondary accounts I tried? I can't figure the logic or reasoning why this would be the case. Is this new or have I been just using primary user/pass in the past?
Any ideas?
    I've seen this before - apparently, some ISP's restrict outgoing to primary accounts. Since it's no problem to configure a mail client to receive on one account, but send on another with the "reply to" field reflecting the receive account, it can be done entirely transparently to the end user. I can only imagine it's easier or cheaper somehow to virtualize POP3 accounts than SMTP.
