Keypad Builder Install Trouble
Greetings,
I'm installing ketpad builder on a freshly buily XP SP3 machine. During installation the program slows down as it skips many files for install. I'm up to about seven minutes and still going.
Any ideas?
  • Having the same problems with Vista.... Did you find a solution?
    It finally comlpeted its install after twenty minutes or so. I have yet to go to Vista, I'm in no rush.
  • When I read my install dialogue, it says skipping file... when it slows down.
    kbeattyAMX wrote: »
    Same thing that happens here. It will finish eventually. Be patient. Let it run over dinner!
  • bjraybjray Posts: 2
    Solution!
    Ok. I realize that I am replying to a thread that's about 3 years old. However, no solution has been posted that I could find and I ran into this issue recently.
    I am running Windows 7 x64. I also am running XP mode and could not install Keypad Builder in either one!
    The install would run, but about a quarter way through it would say something to the effect of "skipping files.." and it would slow down and run the CPU almost 100% and never would finish!
    Steps to resolve:
    In windows explorer, navigate to:
    Windows 7 = C:\Program Files (x86)\AMX Control Disc ---> and delete the folder reference of Keypad Builder
    Windows XP = C:\Program Files\AMX Control Disc ---> and delete the folder Keypad Builder
    Then navigate to:
    Windows 7 = C:\Program Files (x86)\Common Files\AMXShare ---> and delete the folder Keypad Builder Support Files
    Windows XP = C:\Program Files\Common Files\AMXShare ---> and delete the folder Keypad Builder Support Files
    Finally, install (or reinstall) the program Keypad Builder.
    It should complete in less than 1 minute!
    Till next time,
    Brandon
  • AuserAuser Posts: 506
    Nice, thanks for the tip.
