how to send AVP_KEYS?
adys
in MAX by AMX
My AVP remote is damaged before I learned it...
I want to use the IR CODES that in the manual.
http://www.amx.com//techdocs/MAX-AVP.InstructionManual.pdf
From what I undestand, I need to send this command via AVP_KEYS?
Can anyone exaplain how to start with it?
I didn't find nothing on the manual and in the forum...
The last UI module support only part of the commands I need ( table 4 at the module document), and in the manual I have text commands...
Ady.
Ady.
The command syntax is The DUET MAX module has some more key numbers (where numbers 1..49 are the same arrangement), and handling and syntax are different.
