Discrete IR Codes for Panasonic DVD player
Hi,
does anyone of you have any 'Power On&Off' discrete IR codes for Panasonic DVD player S53 ?
try these
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=pronto&db=discrete&br=panasonic&dv=dvdplayer
Contacting the mfg rarely gets you anywhere. I usually find them from various other control system companies or from this forum.
Not to sound condescending (sp?) but, did you also remember to upload the new IR file into the IR port after copy/pasting/saving? I say this because I've done this before many times. You have to copy/paste in and then remember to hit save. Then after that make sure to upload it to the NI's IR port.
I'm only saying this because I've shot myself in the foot many times doing the same thing.
--John
You could, but there is always the possibility of someone turning it off manually, and then you would be turning it on instead of off in a shutdown. One thing to avoid that is just leave it on and send a stop on shutdown, but what I usually do is send a play to make sure it's on, wait however long that model needs to fire up, then send the power toggle to shut it off. It delays shutdown by the length of that wait, but it's not usually too bad.
Power On:
0000 0070 0000 0032 0080 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0030 0010 0030 0010 0030 0010 0030 0010 0010 0010 0010 0010 0010 0010 0030 0010 0030 0010 0030 0010 0010 0010 0010 0010 0010 0010 0030 0010 0AB7
Power Off:
0000 0070 0000 0032 0080 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0030 0010 0030 0010 0030 0010 0030 0010 0030 0010 0010 0010 0010 0010 0030 0010 0030 0010 0030 0010 0030 0010 0010 0010 0010 0010 0010 0010 0030 0010 0AB7
