Home AMXForums Archive Threads AMX Applications and Solutions VisualArchitect
User Interface Element Issues. Another question to test the professionals!
In Visual Architect, when I add a device, lets say for example an iLight generic dimmer; why does VA panel builder treat it like a placeholder when it has a device template. (i.e. "Lighting" which was specified in the CSD window)
It means that when I go to customise my user interface, I have a blank page. With no UI-Element options in the right hand window, I cant add buttons, so I cant access my Control Strings that I programmed to the buttons in Code Builder.
Is there any way to manually apply elements? Or should I just pick a different device type that I know will populate this window properly and then change the text on the buttons?
Any ideas would be much appreciated!
Thanks!
  • Sorted.
    Found the setting to change the page's template model.
