AXT-CP Image Quality
Greetings,
I have a customer that has six AXT-CP's in their business. All of them are running G3 firmware. The image quality on the panels are all various levels of blah. They have far less overall contrast and brightness than a newer AXT-CA10 that is also in the facility. I suspect this may be from age, but I was not into this when the AXT-CPs were new. The saleman solution to the problem would be to upgrade all of the panels to something new. However, I was wondering if they could be improved with new LCD panels or some other repair. The fuctionality of the panels in the system is fine. An upgrade to Modero would only improve the visual.
Thank you for any suggestions.
LCD displays are not interchangeable. The electronics that drive them are usually specifically designed for a particular display model.
