Issues with LENGTH_STRING accuracy
Hey Programmer types:
I'm hitting my head against a brick wall here: I must be missing something easy. Here's the scenario:
bufARQ1 is a CHAR array of size 256, that is linked via CREATE_BUFFER to the device dvARQ1, an AudioReQuest.
My DEFINE_PROGRAM is this: if(LENGTH_STRING(bufARQ1)) ARQ_PARSE();
ARQ_PARSE() does this:
DEFINE_FUNCTION ARQ_PARSE(){
    STACK_VAR CHAR thisMSG[100]
    if(!FIND_STRING(bufARQ1,"$FF,$FB",1)) return; // no terminator
    thisMSG = REMOVE_STRING(bufARQ1,"$FF,$FB",1);
    SEND_STRING 0, "'arqMSG[',itoa(LENGTH_STRING(thisMSG)),']:',thisMSG";
But sometimes the SEND_STRING 0 is reached when the terminator does not appear in bufARQ. Furthermore, when this happens, the length of the string thisMSG is being reported incorrectly!
Line     86 (16:05:47):: AudioReQuest 0:4:0 is ONLINE
Line     87 (16:05:47)::   IP:   10.1.10.65
Line     88 (16:05:47)::   PORT: 3663
Line     89 (16:05:47):: arqMSG[4]:s$F1$FF$FB
Line     90 (16:05:47):: arqMSG[13]:2!$01GRAPHIC$F1$FF$FB
Line     91 (16:05:47):: arqMSG[16]:2$12$07Artists =>$F1$FF$FB
Line     92 (16:05:47):: arqMSG[13]:2!$02GRAPHIC$F1$FF$FB
Line     93 (16:05:47):: arqMSG[15]:2$12$08Albums =>$F1$FF$FB
Line     94 (16:05:47):: arqMSG[13]:2!$03GRAPHIC$F1$FF$FB
Line     95 (16:05:47):: arqMSG[15]:2$12$09Genres =>$F1$FF$FB
Line     96 (16:05:47):: arqMSG[13]:2!$04GRAPHIC$F1$FF$FB
Line     97 (16:05:47):: arqMSG[17]:2$12$0ANow Playing$F1$FF$FB
Line     98 (16:05:47):: arqMSG[13]:2!$05GRAPHIC$F1$FF$FB
Line     99 (16:05:47):: arqMSG[18]:2$12$0BPlaylists =>$F1$FF$FB
Line    100 (16:05:47):: arqMSG[13]:2!$06GRAPHIC$F1$FF$FB
Line    101 (16:05:47):: arqMSG[6]:2$12$0C$F1$FF$FB
Line    102 (16:05:47):: arqMSG[6]:2$12$0D$F1$FF$FB
Line    103 (16:05:47):: arqMSG[14]:2!
Line    104 (16:05:47):: arqMSG[8]:2$12$03
Line    105 (16:05:47):: arqMSG[10]:2$12$02Home$F1$FF$FB
etc.
Regard lines 103 and 104. Is there some tricky thing with the length of the string going on? Anyone here know how this is possible?
    mpullin wrote: »
    I?ll guess that there are NULLs in the string and SEND_STRING 0 is choking on them. Unfortunately SEND_STRING 0 treats strings as NULL terminated. I?ll bet the data is there and that LENGTH_STRING is correct. Instead of doing a SEND_STRING 0 try a SEND_STRING to a virtual device and watch that virtual device in Notifications, that?s the workaround I?ve been using. Notifications works properly. You can?t count on Diagnostics for cases like this.
    I seem to recall a similiar problems with nulls that took forever to figure out. I probably just created a function to clean the string prior to sending.
  • mpullinmpullin Posts: 949
    :headslap:
    Joe Hebert wrote: »
    Thanks Joe. I remember now that Diagnostics stops printing when it sees $00... but for some reason I didn't think that my problem could be in the diagnostics step itself!
    If only we could see notifications from Ethernet devices directly.......
    I routinely run my diagnostics messages through a little filter to avoid such issues:
    DEFINE_FUNCTION CHAR[5096] sCleanAscii (CHAR sString[])
        STACK_VAR CHAR sTemp[5096] ;
        STACK_VAR INTEGER nCount ;
        FOR(nCount = 1; nCount <= LENGTH_STRING(sString); nCount ++)
    	SELECT
    	    ACTIVE(sString[nCount] < 32) : // low order ASCII
    		sTemp = "sTemp, '<', ITOA(sString[nCount]), '>'"
    	    ACTIVE(sString[nCount] > 126) : // high order ASCII
    	    ACTIVE(TRUE) : sTemp = "sTemp, sString[nCount]" ;
        RETURN sTemp ;
    This would output '<0>' in place of any nulls without "breaking" the regular ASCII characters. I have another version that replaces the ITOA with ITOHEX if I want hex notation instead of decimal.
  • AMXJeffAMXJeff Posts: 450
    PrintHex
    I normally convert my strings to ASCII in order to make sure what I am actually getting when doing send string 0... Two of the function I tend to use...
    Define_Function Char[1000] PrintHex(Char cString[])
      Stack_Var Char cTString[100],cHexString[1000],cChar;
      cTString = cString
      cHexString = '"'
      While(Length_String(cTString))
        cChar = Get_Buffer_Char(cTString);
        cHexString = "cHexString,'$',Itohex(cChar/$10),Itohex(cChar&#37;$10),','"
      Set_Length_String(cHexString,Length_String(cHexString)-1);
      cHexString = "cHexString,'"'";
      Return cHexString;
    Define_Function Char[1000] PrintAsciiHex(Char cString[])
      cTString = cString
      cHexString = '"'
        IF (cChar >= 32 && cChar <= 126)
          IF (cHexString[LENGTH_STRING(cHexString)-1] = 39)
            Set_Length_String(cHexString,Length_String(cHexString)-2);
            cHexString = "cHexString,cChar,39,','"
          ELSE
            cHexString = "cHexString,39,cChar,39,','"
        ELSE
          cHexString = "cHexString,'$',Itohex(cChar/$10),Itohex(cChar%$10),','"
      Return cHexString;
