Home AMX User Forum AMXForums Archive Threads AMX Hardware AutoPatch Forum
Linking outputs
Is there an easy way to link two outputs, so that every input/volume setting was automatically duplicated on the second output, basically internally creating the same effect as putting a "Y" adapter on the output of a zone to feed multiple amps?
    It's all in the string you send it. If you want all 18 outputs to use the same input and at the same volume you just write a string to do so. You can do any combination of inputs to outputs and volume setting you want and once you familarize yourself with the protocol you'll find it very simple.
