Firmware Upgrade Going Wrong
From time to time I have a problem with MVP memory cards (CF) going dead, if by upgrading failures or by any other reason by the god of smart houses.
Because of my location it takes a lot of time for the new CF card AMX is sending me to reach me. sometimes I'm doing a project that is a 100 miles from the office and a CF goes dead and i waste a whole day just driving back to the office and getting a new MVP CF... so i'm stuck with 2-3 panels with no memory card, and my stock is running low for no reason... I know that the Firmware AMX is putting inside the CF is protected, i tried to put a CF card in a reader and it won't even recognize it.
Isn't there a way to copy a good CF to another CF? Can't AMX publish a program that would only flash an empty CF card?
Thanks for the help
Ronen Katz
Hed-Cinema
Herzlia, ISRAEL
    Download Winhex and register your copy. It can make an image file of a good CF that you can use to restore a bad one, or to replace a bad card. I struggled with many methods of doing this, including Linux boot discs, but the image solution was, by far, the easiest. You will also need a CF reader, which you can get pretty cheap just about anywhere that sells computer parts.
  • RonenRonen Posts: 55
    Thanks for the answer DHawthorne,i will try it soon.
    btw, if i want to increase the size of my 64MB CF card to 256MB wouldn't the imge file restrict me to only 64MB?
    Ronen
    Ronen wrote: »
    Ronen
    Yes, the image would contain the partition data. At that point you would need to adjust the partition size; for panels it's a Linux partition, so you would need to know how to do it there (beyond my knowledge, I'm afraid).
    Sometime next week...
    well, i'm gonna deal with this next week, if i find an easy way to change the partition size i will post it here.
    Thanks again for all the help
