Just to note, if you issue the POWER=0 command to turn off the server, you have to manually turn it back on. It can't be turned back on by code.
If you're trying to turn off the AVP and not the server then you could issue the commands below (where nZone is the AVP that you're trying to control):
Send_Command vdvMAXModule, "'AVP_KEYS=',ITOA(nZone),':45'" //Turns the AVP off
or
Send_Command vdvMAXModule, "'AVP_KEYS=',ITOA(nZone),':44'" //Turns the AVP on
Yes,
I'm not at my machine right now to give you the exact code. But, I think it's something like Power=0.
thank
Yes, send_command vdv_MAX_Module
If you're trying to turn off the AVP and not the server then you could issue the commands below (where nZone is the AVP that you're trying to control): or
--John
