IR File: Transfer Aborted - Incompatible Version.
I must replace a NI-3000 with a NI-3100..
So I dumped the code in the NI-3100 but only one IR file won't be transferd and gives the following error:
A other IR file gives no problems.
I use the latest version of Netlinx studio
Who can help me?
  • AMXJeffAMXJeff Posts: 450
    Did you try to call Tech Support?
  • PetarPetar Posts: 14
    Nope... maybe I can give it try to call :)
    Whehe.. I've tryed to call the tech support... only from abroad it is not possible to make a choice in menu :') So, i keep staying in the rotation thing :P
    Can somebody give me the direction phonenumber for the AMX Tech support desk?
    The solution:
    Proper device mapping is the solution ;)
    800.932.6993
  • how did you solve the issue with ir loading?
    i can wait until tomorrow to call amx : )
    thanks
    bogdandr wrote: »
    thanks
    The device mapping is what he referred to. If improperly mapped he might have been trying to upload to a relay or rs232 port or something. (which is, of douse, the wrong format)
    There shouldn't be a mapping issue from a 3000 to a 3100, they have the same ports. I'd be more inclined to suspect a corrupt IR file.
