Timeline times as an array
I'm in a bit of a quandary on Timelines. I realize I can't do an array on the Timeline ID and that is fine. However what I'm wanting to know is can you create an array of times and put that into the timeline create. The reason I'm asking is because I'm trying to create an include file that has the capability of controlling up to 10 projectors/displays. The time array doesn't seem to be working for me. Here is some code for you to ponder.
The nTL_CountdownTime_UniversalDisplay array propogates the two times perfectly, however when the function is called the timelines do not start. If I change nTL_CountdownTime_UniversalDisplay to this:
And change the timeline_create to this:
The code works beautifully and as expected. The problem is the warmup and cooldown times will be the same for all 10 devices and I may not want them to be. I want to be able to set different warmup and cooldown times for any of the 10 devices if need be.
Is this even possible?
DEFINE_CONSTANT cDVAryIdx_1_UniversalDisplay__ = 1 cDVAryIdx_2_UniversalDisplay__ = 2 cDVAryIdx_3_UniversalDisplay__ = 3 cDVAryIdx_4_UniversalDisplay__ = 4 cDVAryIdx_5_UniversalDisplay__ = 5 cDVAryIdx_6_UniversalDisplay__ = 6 cDVAryIdx_7_UniversalDisplay__ = 7 cDVAryIdx_8_UniversalDisplay__ = 8 cDVAryIdx_9_UniversalDisplay__ = 9 cDVAryIdx_10_UniversalDisplay__ = 10 cTL_CountdownOffset_UniversalDisplay__ = 30000 cTL_Dev1_Countdown_UniversalDisplay__ = 30001 cTL_Dev2_Countdown_UniversalDisplay__ = 30002 cTL_Dev3_Countdown_UniversalDisplay__ = 30003 cTL_Dev4_Countdown_UniversalDisplay__ = 30004 cTL_Dev5_Countdown_UniversalDisplay__ = 30005 cTL_Dev6_Countdown_UniversalDisplay__ = 30006 cTL_Dev7_Countdown_UniversalDisplay__ = 30007 cTL_Dev8_Countdown_UniversalDisplay__ = 30008 cTL_Dev9_Countdown_UniversalDisplay__ = 30009 cTL_Dev10_Countdown_UniversalDisplay__ = 30010 DEFINE_VARIABLE VOLATILE LONG nTL_CountdownTime_UniversalDisplay__[10][2] //10 Devices, 2 Times - Warmup/Cooldown (***********************************************************) (* SUBROUTINE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_FUNCTION fnSendPowerCmd_UniversalDisplay__(DEV __dvDev, INTEGER __nDevIdx, INTEGER __PwrCmd) { SWITCH(__PwrCmd) { CASE 0: { //Execute if __PwrCmd = 0 (OFF) IF(uFdbk_UniversalDisplay__[__nDevIdx].Power) { //Execute if Power State is On IF(nCountdownStatus[__nDevIdx] = cDeviceStatus_Ready_UniversalDisplay__) { //Execute if Device is Ready SEND_STRING dvDEVs_UniversalDisplay__[__nDevIdx],"uCmds_UniversalDisplay__[__nDevIdx].PowerOff" uFdbk_UniversalDisplay__[__nDevIdx].Power = cDevicePowerState_Off IF(![dvDEVs_UniversalDisplay__[__nDevIdx],cFnChnl_DisableCountdown_UniversalDisplay__]) { //Change Device Status and Start Countdown if DisableCountdown Flag is not Enabled nCountdownStatus[__nDevIdx] = cDeviceStatus_Cooling_UniversalDisplay__ [b]TIMELINE_CREATE(cTL_CountdownOffset_UniversalDisplay__+__nDevIdx,nTL_CountdownTime_UniversalDisplay__[__nDevIdx],LENGTH_STRING(nTL_CountdownTime_UniversalDisplay__[__nDevIdx]),TIMELINE_ABSOLUTE,TIMELINE_REPEAT)[/b] } } } ELSE { //Execute if Power State is Off SEND_STRING dvDEVs_UniversalDisplay__[__nDevIdx],"uCmds_UniversalDisplay__[__nDevIdx].PowerOff" } } DEFAULT: { //Execute if __PwrCmd is Anything but 0 (ON) IF(!uFdbk_UniversalDisplay__[__nDevIdx].Power) { //Execute if Power State is Off IF(nCountdownStatus[__nDevIdx] = cDeviceStatus_Ready_UniversalDisplay__) { //Execute if Device is Ready SEND_STRING dvDEVs_UniversalDisplay__[__nDevIdx],"uCmds_UniversalDisplay__[__nDevIdx].PowerOn" uFdbk_UniversalDisplay__[__nDevIdx].Power = cDevicePowerState_On IF(![dvDEVs_UniversalDisplay__[__nDevIdx],cFnChnl_DisableCountdown_UniversalDisplay__]) { //Change Device Status and Start Countdown if DisableCountdown Flag is not Enabled nCountdownStatus[__nDevIdx] = cDeviceStatus_Warming_UniversalDisplay__ [b]TIMELINE_CREATE(cTL_CountdownOffset_UniversalDisplay__+__nDevIdx,nTL_CountdownTime_UniversalDisplay__[__nDevIdx],LENGTH_STRING(nTL_CountdownTime_UniversalDisplay__[__nDevIdx]),TIMELINE_ABSOLUTE,TIMELINE_REPEAT)[/b] } } } ELSE { //Execute if Power State is On SEND_STRING dvDEVs_UniversalDisplay__[__nDevIdx],"uCmds_UniversalDisplay__[__nDevIdx].PowerOn" } } } } DEFINE_START nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_1_UniversalDisplay__][1] = 65000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_2_UniversalDisplay__][1] = 65000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_3_UniversalDisplay__][1] = 65000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_4_UniversalDisplay__][1] = 65000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_5_UniversalDisplay__][1] = 65000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_6_UniversalDisplay__][1] = 65000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_7_UniversalDisplay__][1] = 65000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_8_UniversalDisplay__][1] = 65000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_9_UniversalDisplay__][1] = 65000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_10_UniversalDisplay__][1] = 65000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_1_UniversalDisplay__][2] = 70000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_2_UniversalDisplay__][2] = 70000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_3_UniversalDisplay__][2] = 70000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_4_UniversalDisplay__][2] = 70000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_5_UniversalDisplay__][2] = 70000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_6_UniversalDisplay__][2] = 70000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_7_UniversalDisplay__][2] = 70000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_8_UniversalDisplay__][2] = 70000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_9_UniversalDisplay__][2] = 70000 nTL_CountdownTime_UniversalDisplay__[cDVAryIdx_10_UniversalDisplay__][2] = 70000 DEFINE_EVENT TIMELINE_EVENT[cTL_Dev1_Countdown_UniversalDisplay__] TIMELINE_EVENT[cTL_Dev2_Countdown_UniversalDisplay__] TIMELINE_EVENT[cTL_Dev3_Countdown_UniversalDisplay__] TIMELINE_EVENT[cTL_Dev4_Countdown_UniversalDisplay__] TIMELINE_EVENT[cTL_Dev5_Countdown_UniversalDisplay__] TIMELINE_EVENT[cTL_Dev6_Countdown_UniversalDisplay__] TIMELINE_EVENT[cTL_Dev7_Countdown_UniversalDisplay__] TIMELINE_EVENT[cTL_Dev8_Countdown_UniversalDisplay__] TIMELINE_EVENT[cTL_Dev9_Countdown_UniversalDisplay__] TIMELINE_EVENT[cTL_Dev10_Countdown_UniversalDisplay__] { LOCAL_VAR INTEGER __nID LOCAL_VAR INTEGER __nSequence __nID = TIMELINE.ID - cTL_CountdownOffset_UniversalDisplay__ __nSequence = TIMELINE.SEQUENCE SWITCH(TIMELINE.SEQUENCE) { CASE 1: { IF(nCountdownStatus[__nID] = cDeviceStatus_Warming_UniversalDisplay__ || nCountdownStatus[__nID] = cDeviceStatus_NotReady_UniversalDisplay__) { TIMELINE_KILL(__nID+cTL_CountdownOffset_UniversalDisplay__) nCountdownStatus[__nID] = cDeviceStatus_Ready_UniversalDisplay__ } } CASE 2: { IF(nCountdownStatus[__nID] = cDeviceStatus_Cooling_UniversalDisplay__ || nCountdownStatus[__nID] = cDeviceStatus_NotReady_UniversalDisplay__) nCountdownStatus[__nID] = cDeviceStatus_Ready_UniversalDisplay__ } } }
VOLATILE LONG nTL_CountdownTime_UniversalDisplay__[] = {65000,70000}
TIMELINE_CREATE(cTL_CountdownOffset_UniversalDisplay__+__nDevIdx,nTL_CountdownTime_UniversalDisplay__,LENGTH_STRING(nTL_CountdownTime_UniversalDisplay__),TIMELINE_ABSOLUTE,TIMELINE_REPEAT)
Here is a pseudo-timeline array.
You can do a timeline create numbering the timelines 1-10 as devices require. The above event will trigger from any of the timelines. nNumber will tell you which one.
I did a little experiment like this as well. My main concern was: will triggering a second event while the first one is running cancel or goof up the variables of the currently running timeline(s). To my joy, it did not. So, in a sense, it is truly a timeline array. I imagine it's just a matter of rewriting the complier to allow for it in the source code.
Right, and I have that in my code but that is not what I'm asking. I'm wanting to know why I can't create a multidimensional array for the times or if I can what am I doing wrong. Below is simpler example of what I'm trying to accomplish using only 3 devices:
With the code above the timelines never become active. However if I change my code to this:
All three timelines become active when they are supposed to. The problem with the second example is that I have to have the same warmup and cooldown times for all three displays. 95% of the jobs that I program for there is at least 1 projector and 1 or more plasma/LCD displays. It wouldn't be practical for me to have 65 seconds of warmup/cooldown time on the plasma/LCD.
Sorry about the mess of code I posted previously. It's been a long week and didn't think about creating something simpler.
1) Remove your DEFINE_START code and change this:
To this:
Or:
2) Leave everything as is and add these three lines to the end of DEFINE_START:
Wow, didn't even know you could do that. It did the trick though, thanks.
