Writing an Integer Array to Flash
Greetings,
I know that this is incomplete code, but hopefully you'll get the point!
Is the second line of code above correct for encoding the entire array? Or must there be a [] after nInetgerArray?
INTEGER nIntegerArray[10] VARIABLE_TO_STRING (nIntegerArray,cConvertedValue,1) FILE_WRITE (slFileHandle,cConvertedValue,LENGTH_STRING(cConvertedValue))
Another problem is how do I get all of the integer value from the encoded string back into the integer array in one shot?
STRING_TO_VARIABLE (nValue,cConvertedValue,1) //In a function RETURN nValue nIntegerArray[]=ReadIntegerFromFlash('FILE_NAME.dat') //In a main program eventDEFINE_FUNCTION fnFileWrite_ToFile(CHAR iWriteFileName[],CHAR iWriteFileBuf[],INTEGER iIOFlag) { //filename //var w/ data to write // 1 (FILE_READ_ONLY) = The file is opened with READ ONLY status stack_var slong nWriteFHandle ; // 2 (FILE_RW_NEW) = The file is opened with READ WRITE status stack_var slong nWriteFResult ; // 3 (FILE_RW_APPEND) = The file is opened with READ WRITE status nWriteFHandle = file_open(iWriteFileName,iIOFlag) ; if (nWriteFHandle > 0) { if(nMain_DeBug) { SEND_STRING 0,"'FUNCTION fnFileWrite_ToFile. File_Open successful for *', iWriteFileName,'*! line-<',ITOA(__LINE__),'>',crlf" ; } nWriteFResult = FILE_WRITE (nWriteFHandle,iWriteFileBuf,length_string(iWriteFileBuf)) ; if(nWriteFResult > 0) { if(nMain_DeBug) { SEND_STRING 0,"'FUNCTION fnFileWrite_ToFile. File_Write OK. Wrote a ', itoa(nWriteFResult),' CHAR String! line-<',ITOA(__LINE__),'>',crlf" ; } } else { stack_var char cErrorMsg [20] ; switch (itoa(nWriteFResult)) { case '-11': {cErrorMsg = 'disk full'} ; case '-6' : {cErrorMsg = 'invalid parameter buffer !> 0'} ; case '-5' : {cErrorMsg = 'disk I/O error'} ; case '-1' : {cErrorMsg = 'invalid file handle'} ; } if(nMain_DeBug) { SEND_STRING 0,"'FUNCTION fnFileWrite_ToFile. Bad File_Write_Line: ',cErrorMsg, '! line-<',ITOA(__LINE__),'>',crlf" ; } } } else { stack_var char cErrorMsg [40] ; switch (itoa(nWriteFHandle)) { case '-2': {cErrorMsg = 'invalid file path or name'} ; case '-3': {cErrorMsg = 'invalid value supplied for IOFlag'} ; case '-5': {cErrorMsg = 'disk I/O error'} ; case '-14':{cErrorMsg = 'max number of files are already open'} ; case '-15':{cErrorMsg = 'invalid file format'} ; } if(nMain_DeBug) { SEND_STRING 0,"'FUNCTION fnFileWrite_ToFile. Bad File_Open: ',cErrorMsg, '! line-<',ITOA(__LINE__),'>',crlf" ; } } file_close(nWriteFHandle) ; RETURN ; }DEFINE_FUNCTION WriteIntegerArrayFlash(CHAR cFileName[], INTEGER nValue[]) { STACK_VAR SLONG slFileHandle; STACK_VAR CHAR cConvertedValue[1000]; // SOME BUG WITH VARIABLE TO STRING... INTEGER ARRAYS NEED LENGTH IF (LENGTH_ARRAY(nValue) == 0) SET_LENGTH_ARRAY(nValue,MAX_LENGTH_ARRAY(nValue)); // NOT ENOUGH SPACE IN YOUR ARRAY IF (MAX_LENGTH_STRING(cConvertedValue) < LENGTH_VARIABLE_TO_STRING(nValue)) { SEND_STRING 0,"'WriteIntegerArrayFlash: Error, NOT ENOUGH SPACE!!!'" RETURN; } slFileHandle = FILE_OPEN(cFileName, FILE_RW_NEW); // VALID FILE HANDLE IF (slFileHandle > 0) { VARIABLE_TO_STRING(nValue, cConvertedValue, 1); FILE_WRITE(slFileHandle, cConvertedValue, LENGTH_STRING(cConvertedValue)); FILE_CLOSE(slFileHandle); } } DEFINE_FUNCTION ReadIntegerArrayFlash(CHAR cFileName[], INTEGER nValue[]) { STACK_VAR SLONG slFileHandle; STACK_VAR CHAR cConvertedValue[1000]; // NOT ENOUGH SPACE IN YOUR ARRAY IF (MAX_LENGTH_STRING(cConvertedValue) < LENGTH_VARIABLE_TO_STRING(nValue)) { SEND_STRING 0,"'ReadIntegerArrayFlash: Error, NOT ENOUGH SPACE!'" RETURN; } slFileHandle = FILE_OPEN(cFileName, FILE_READ_ONLY); // VALID FILE HANDLE IF (slFileHandle > 0) { FILE_READ(slFileHandle, cConvertedValue, MAX_LENGTH_STRING(cConvertedValue)); STRING_TO_VARIABLE(nValue, cConvertedValue, 1); FILE_CLOSE(slFileHandle); } }
