Keypad on panel
If i create a keypad that I want to use to store number data would it look like this?
DEFINE_EVENT
Button_Event[dvPanel,100]
Push:
SEND_COMMAND dvPanel,"'AKEYP'"
This pops up my keypad but how do i store each button i hit on the keypad as a variable?
Buttonpushes = (Get_last,buttonpushes)
1
14
147
1478
14789
etc...
    You need to create a data_event for the touch panels on port 1. The numbers entered with the keypad will be sent as a String: event from the touch panel. The format of the text will be KEYP-###### where the #s will be the numbers entered.
    Once you have the text, you can break it apart as needed of convert it to numbers using ATOI or similar.
  • davidvdavidv Posts: 90
    Keypad issue
    Is this correct?
    DEFINE_EVENT
    BUTTON_EVENT[dvPanel,69]
    Push:
    Data_Event[dvPanel]
    Online:
    Wait 25
    Clear_Weather_Data()
    STRING:
    LOCAL_VAR CHAR cBuffer[10]
    cBuffer = DATA.TEXT
    SELECT
    ACTIVE (FIND_STRING(cBuffer,'KEYP',1)):
    REMOVE_STRING(cBuffer,'KEYP-',1)
    ZIP_NUM = ("cBuffer")
    cZip = ZIP_NUM
    ACTIVE (FIND_STRING(cBuffer,'KEYB',1)):
    REMOVE_STRING(cBuffer,'KEYB-',1)
