Compiler/Vista
I'm running NS2 on my desktop (Vista) and my laptop (XP). When I compile on XP, it happens almost instantaneously. When I compile on vista, it hangs for a good 10 seconds before the compile actually happens, and the compiler is still technically "running" for 15 - 20 seconds after that. This means that if I fix a small error (missing bracket or something), and hit Compile again within that time limit, I get an alert that the Netlinx compiler is already running.
This is the only problem I have with NS2 on vista. Has anyone else run into this, and is there a known fix?
J
J
I'm also running Vista on a laptop, running Netlinx 2.8b, but I don't get any sort of delay. One possibility, however, is that it's being caused one of the many Vista "features" that I've carefully stalked and destroyed. In any case, I suppose that means that the issue isn't permanent.
