ADA audio
                    I have an ADA Suite 8x8 and a Duo Tuner hooked into a ADA System Controller piece. From there they go into my master VIA RS232 port 1.
I downloaded all the AMX modules. For starters the modules that are posted wouldnt compile. Some of the files were missing. I called tech support and they informed me to remove those files and load the .tko files in their place. I did this and now I can at least see the commands being sent out and my TX, and RX lights on my master are flashing. However the ADA gear is not actually doing anything.
Has anyone been able to get the ADA gear working?
Do you have the functional module files?
David.Valego@jarmac.com
I am using a suite 8x8. I did the same thing as you and it finally compiled but I am unable to control it. I do see the TX and RX lights flashing when I push a button but there is no control.
Line 1 (11:17:04):: Input Status:Pushed [10001:41:1] - Channel 41
Line 2 (11:17:04):: Command To [10001:41:1]-[@TXTeTuner]
Line 3 (11:17:04):: Command To [33001:1:1]-[SWITCH=A:1:1]
Line 4 (11:17:04):: Command From [33001:1:1]-[SWITCH=A:1:1]
Line 5 (11:17:04):: Input Status:Pushed [10001:4:1] - Channel 10
Line 6 (11:17:04):: Input Status:Pushed [10001:4:1] - Channel 10
Line 7 (11:17:04):: Feedback:Off [10001:4:1] - Channel 10
Line 8 (11:17:04):: Output Channel:Off - From [10001:4:1] - Channel 10
Line 9 (11:17:04):: Feedback:On [10001:4:1] - Channel 10
Line 10 (11:17:04):: Output Channel:On - From [10001:4:1] - Channel 10
Line 11 (11:17:04):: Command To [10001:4:1]-[@PPF-XM_Controls]
Line 12 (11:17:04):: Command To [10001:4:1]-[@PPF-XM Presets]
Line 13 (11:17:04):: Input Status:Released [10001:41:1] - Channel 41
Line 14 (11:17:05):: String To [33004:1:1]-[`SAD01R01$0D]
Line 15 (11:17:05):: String From [33004:1:1]-[`SAD01R01$0D]
Line 16 (11:17:05):: String To [5001:1:1]-[`SAD01R01$0D]
Line 17 (11:17:05):: String From [5001:1:1]-[`SAD01R01$0D]
Line 18 (11:17:05):: Input Status:Released [10001:4:1] - Channel 10
Line 19 (11:17:05):: Input Status:Released [10001:4:1] - Channel 10
The pin out for ADA is:
ADA
TX 2
RX 3
GND 5
AMX
TX 2
RX 3
GND 1
Is this correct?
Don't you have documentation for this piece? Are you using a pre-made RS-232 cable? Try making your own only hooking up pins 2, 3 and 5.
IF it is a captive screw connection for AMX GND is 1 RX is 2 and TX is 3.
Also one thing I found for the Tuner control on the 8200 piece was that a zone had to be turned on in order for the tuner to do anything.
The RS232 cable was shorting out and the back of the Control Suite was in IR mode. I had to switch the back of the Control Suite to RS232 control.
Thanks for the help
