HELP!!!! Tivo IR problems...Sluggish op.
in AMX Hardware
I hope someone out there can help or may have seen this same problem. Intermittently when operating series 2 Tivo units and even at times the DirecTV Tivos the units seem to have very sluggish response or may not respond at all. I have learned the IR a few different times and programmers at our other locations have had the same problems with their IR files. Also if you try and go into Tivo setup on a networked series 2, the setup inside the Tivo gets all funky, even if you back out without making changes. You then need to go back in with the original remote and fix the messed up settings. If you have seen these or other problems please let me know.
Thanks, in advance for any help,
Robb
Robb
Happy to break out of lurking mode for this one.
My problem was with a DirecTV TiVO HD unit.
I relearned all of the codes with an IRIS, this was a previously working Philips irl file, never a hint of a problem with it, and this sluggish behavior caused at least 3 embarrasing service calls, countless hours on the phone with Tech Support (tried everything, including port/cable swaps). Of course it never happened consistently when I was on site during normal hours, only end of my day or when client came home after his long day!
Relearned codes and put everything into timelines. No problems since.
FWIW my IRL file is attached.
Not too familiar with time lines especially using them to control an IR device. Could you flip me an example?
Thanks for your help on this!
no points for elegance, but it works..
Also when you learn with the Iris, it makes a huge difference how long you hold each button down for. Aim for short, especially with arrows and numbers.
Also also, I think there are just some Tivo's out there which are super sluggish. It's possible they're busy getting info from the sat. or something, but I've noticed they're extremely variable. The new Hughes HD Tivo is so unreliable that one dealer I work for refuses to sell them - will integrate them into a system, but won't take responsibility for them.
OP
thanks oliver, i had the same issue with a new basic directv model, it would not take same digit close together, it was house audio, same job.
Bottom line from trainers and tech support: no more lazy waits.
OP
I have never used XCH for the reasons you all describe. I use stacked pulses instead.
In the example below, nDSS_NUM is an integer array of DSS station numbers. The index of the array is passed to the call from the button push. For device dvDSS, CTON = 1 and CTOF = 4.
DEFINE_CALL 'GET DSS STATION' (INTEGER nINDEX)
LOCAL_VAR
INTEGER nNUM[3]
INTEGER nLOCK_WAIT
INTEGER nDSS_LOCK
IF (!nDSS_LOCK)
ON[nDSS_LOCK]
nNUM[1]=( (nDSS_NUM[nINDEX]/100) +10)
nNUM[2]=(((nDSS_NUM[nINDEX]%100)/10)+10)
nNUM[3]=(((nDSS_NUM[nINDEX]%100)%10)+10)
nLOCK_WAIT = 35
SEND_COMMAND dvDSS," 'SP',nNUM[1] " // Hundreds
SEND_COMMAND dvDSS," 'SP',nNUM[2] " // Tens
SEND_COMMAND dvDSS," 'SP',nNUM[3] " // Ones
// LOCAL HD STATION
IF (nINDEX>=1 AND nINDEX<=8)
nLOCK_WAIT = nLOCK_WAIT + 20
SEND_COMMAND dvDSS," 'SP',75 " // DASH or dot
SEND_COMMAND dvDSS," 'SP',11 " // 1
SEND_COMMAND dvDSS,"'SP',21" // ENTER
WAIT nLOCK_WAIT
OFF[nDSS_LOCK]
Sorry about the formatting, I don't know how to indent the text.
Enjoy!
DEFINE_CALL 'GET DSS STATION' (INTEGER nINDEX) LOCAL_VAR INTEGER nNUM[3] INTEGER nLOCK_WAIT INTEGER nDSS_LOCK { IF (!nDSS_LOCK) { ON[nDSS_LOCK] nNUM[1]=( (nDSS_NUM[nINDEX]/100) +10) nNUM[2]=(((nDSS_NUM[nINDEX]%100)/10)+10) nNUM[3]=(((nDSS_NUM[nINDEX]%100)%10)+10) nLOCK_WAIT = 35 SEND_COMMAND dvDSS," 'SP',nNUM[1] " // Hundreds SEND_COMMAND dvDSS," 'SP',nNUM[2] " // Tens SEND_COMMAND dvDSS," 'SP',nNUM[3] " // Ones // LOCAL HD STATION IF (nINDEX>=1 AND nINDEX<=8) { nLOCK_WAIT = nLOCK_WAIT + 20 SEND_COMMAND dvDSS," 'SP',75 " // DASH or dot SEND_COMMAND dvDSS," 'SP',11 " // 1 } SEND_COMMAND dvDSS,"'SP',21" // ENTER WAIT nLOCK_WAIT OFF[nDSS_LOCK] } }
