NI 3100 communication problem?
in AMX Hardware
Hi
My laptop losses connection to the Nelinx master ,every time i connect to the master .
The NI 3100 Ethernet port is connected to the AMX wireless device to communicate with the MVP 7500 wireless touch panel.
The wireless touch panel communicates with the NI controller no problems here.
I also tried the serial communication for the Ni ,it also connects only temporarily .
But when i connect a LAN cable from laptop to the NI 3100controller ,the Master communication is fine,it does not disconnect.
Also my laptop always detects the master ip when i go into listening mode in master communications TCP/IP mode.
Can somebody help me on this issue and tell me what could be the cause
(this is my first AMX installation)
Maybe AMX should sell one...
I assume from this that you have a wireless access point of some sort connected to your NI3100 and that your wireless TP connects through the access point to the nI3100 and works correctly. I believe that the easiest solution is to have your laptop wireless connect to the access point as well. If you don't have a wireless card in your laptop, or it doesn't work, or if there is some other reason that you don't want to connect yout laptop through the wireless access point, you can get a dumb switch and connect the access point, laptop, and NI3100 all to the switch and you should then have joy.
http://www.amx.com/products/NXA-WAP250G.asp
my laptop wireless connection manager shows two devices amx 1 and amx 2 ,they are from the same wireless access point,i can use either of them and will be able to communicate with NI controller for some time(30-40 seconds).
Could this be the issue that causes me to loose my connection to the master .
Just wondering if you were using a Firewall / Auto Protect / Anti Virus on your Laptop that may be causing your problems, are you able to disable it for say 10 - 15 minutes?
i will try tomorrow to communicate with NI controller thru a switch ,instead of wireless.
Thanks to all for your help
You can turn this message off by terminal/telnet command SET UDP BC RATE<enter>, and setting the value to 0 (zero).
